An attempt to add an IPv4 blackhole route failed.
This system is running low on memory resources. The local or network configuration should be reduced to free up memory resources. ISIS should be disabled and renabled in order to re-acquire the route that could not be installed.
Error
IPv4 route add request for blackhole route failed with error %rc%
| Name | Type |
| rc | sInt |
